![]() I am open to any and all suggestions. I also want to post in each of these areas, so everyone can follow the progress.
founder ![]() Jay ![]() ![]() One good thing about this is it has been together before and with small changes I don't think there will be alot of issues. The only thing I dont like about the body is the fact I left the original mounting holes and now with the Berrien Chassis I will need to make more holes. I hadn't planned to do a Notalgia chassis when I had the body painted and flaked. John
founder ![]() I need to get a new dash. I bought a used one but it got damaged by UPS. I guess I should get a hold of the Manx Club and go with a fresh one with no holes. John
founder ![]() Jay ![]() I had a tank bracket bolt we missed pulling out and the painter painted over. It will not show so it will be fine. I started painting the underside of the tub satin black. I am also going to paint the underside of the fiberglass floor satin black. I'll get some pics tonight. I am in the garage every night from 10pm-1:30am or online at that time. Running on 4 hrs sleep every day now. 60 days left to be ready for this. I may bedliner coat it instead for sound dampening. I spent about 3 hours collecting little parts and things in the garage and getting them into totes. I have 6 gas tanks in the garage and only 3 hold down brackets? Go figure. I think a buddy might have some. I think I will bedliner coat the bottom of the fuel tank as well. Not that I am planning for leaks but, does the bedliner stuff hold up to gasoline????? Anyone used it? I know Tom has linex on the Imp right?
founder ![]()
John, Just dont kill yourself , The body can only handle 4 hours a night of sleep for so long , TAKE a day 8 hours nap its gooood for the sole. Glen
Bremen Speed Equ. Citation #1077
founder ![]() When I dropped it down that big wood block in the front of the body hit the tube frame cross member. I had to get out the grinder and shave off the Meyers wood block. There is no turning back now. She is shaved and need repainted tonight.
founder ![]() I did 2 layers 2 different nights. First layer was with fiberglass cloth. Second with mat. I liked the cloth much better. Hope it comes out okay. John
founder Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
