![]() Jay ![]() Outfront states the EJ 4-cylinder motors with turbo and intercooler come in at 300lbs. I'd guess a N/A motor would be about 15lbs or so less? According to this site (has to be one of the most comprehensive lists of engine weights I've ever seen!): http://www.241computers.com/ford/ContentExpress20-30-38.html They show a dressed VW, DH cooling, dual Kadrons, Monza exhaust, flywheel, clutch etc @ 250lbs. Most sites list the VW engine ~200lbs - but don't say what's on it? (Cooling tin, fan, alternator, exh. etc.?) I'm more inclined to believe the ~250 number. Jeff ![]() Jay
If you look at the Subaru engine as it'll be installed in a Buggy or rail you'll see the weight is only 30-40 lbs different. When I say as it'll be installed in a Buggy or rail I mean minus power steering pump, A/C compressor, belts and cast iron exhaust (75 lbs) the weight difference is the cooling system. I have a rear (VW) rail that had a 6 rib 002 transmission with bus disc breaks converted to mid-engine Subaru with a Subaru 5 speed transmission that weigh's 10 lbs less with the Subaru setup. I wish I still had the VW engine, I'd like to weigh it and see the difference. Maybe Paul still has one sitting around. I know one thing the power difference is majorand more than makes up for the minor weigh difference.
http://mel-adjusted.zoints.com/ ![]() Thanks for the info. I'm not concerned about the weight difference really. I know the power will more than make up for any extra weight it has to haul around. I'm running a swing transaxle and when indexing the arms, I set it up a little on the high side. I did this because I was originally planning to throw my Corvair 140 HP (6 Cyl) on it. I drove around last summer with the tires wearing on the outside edge slightly. When I had two kids in the back, it would ride on the inside on the tires slightly. I'm hoping that I figured correctly for the subaru engine is all. I'm running a 1600 DP with dual kadrons, and generator. I am not running the lower cooling tins or the front or rear tin that would seal up a bug engine bay. It will be interesting to see just how well the suspension settles with a little extra weight. I'm hoping I figured well enough to put about 1000 miles on it before I can do any tweaking with the height. I think I'll be OK though. Jay ![]() In the end it pretty much becomes trial and error anyway! You might also consider running slightly larger torsion bars to help compensate for the extra weight? Unfortunately, I believe the SAW bars make a pretty big jump up in size over stock for their lightest bar, and not sure what OEM bars were used for the swing-axle cars that might be a little larger than the std. Beetle? I'd think you might want to go up a couple of mm in diameter? Interestingly, if I recall correctly the Corvair also comes in around 300lb in Buggy dress - one of the reasons it was so popular (not much heavier than the VW engine). Jeff
Jay ,Good Morning,Maybe make a mock-up frame to fit in your tranny bolt holes and use bar bell weights.? Glen
Bremen Speed Equ. Citation #1077
![]() I know there is no substitution for the real thing, but I like to do my homework, if you know what I mean. I should have mentioned this in my first post, but the big-picture here is this: I am going to be doing a subi engine swap at Mid America. Before you all wonder how this is possible to do in a weekend... I am getting an engine from Dune Engines, LLC (Owned by Paul). This plan is for the engine and radiator to be one unit ready for install. Paul and I have been discussing preps. I am going to wire the buggy ahead of time as much as possible. At this point, I am wondering if there are any good shops in Effingham who can pull off a wheel alignment for a beetle chassis. I recently installed a lowered front beam and had to address a worn tie rod end so the alignment needs to be done. I may as well wait for the extra weight to be hung and do it there if I can. Thanks for everyone's thoughts and suggestions so far! Jay
Well if anyone can pull this off on a weekend it would be Dune Engines LLC. Wish I was there to lend a helping hand... sounds fun
http://mel-adjusted.zoints.com/ ![]() Jeff ![]() I decided to start a new thread about the "build" (swap) here: http://www.dunebuggyarchives.com/forum/topic_show.pl?tid=926 Jay ![]() complete type I Beetle engine in a buggy stock weighs 99 kilo complete type I Beetle engine in a buggy with twin webers weighs 104 kilo complete type IV engine in a buggy converted to upright with a Porsche cooling system and webers weighs 111 kilo A subaru N/A engine can get some unnecessary weight removed "power steering unit, air conditioner unit, large cast iron supporting bracket, 2 engine mounts, and 2 cast iron exaust manifolds, on the scales thay are 22.5 kilo's of weight being lost ![]() On the Funco site they state that a VW typeI turbo engine is the same weight as a Subi N/A but does not include rad and lines Shortly I will be fitting another Subi engine complete and with a Cat and muffler, I will put it on the scales and see what it weights Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
