![]() Anyone have any pics of the original Suby radiator hoses? In particular, I'd like to see the lower hose and how it comes off the water pump - and where it goes from there. DOHC motor (or SOHC?) with pump inlet facing out to the side. I'm trying to figure out if using some or all of the factory lower hose will make plumbing down around the water pump any easier. With the direction the pump inlet faces - coming straight out will hit the timing belt cover/head, so the hose has to drop down a bit to clear? Thanks! Jeff
Jeff, I hope these pics help. There all I have and ther old pics of one of the engine I have.
[IMG]http://img401.imageshack.us/img401/2316/download002al2.th.jpg[/IMG] [IMG]http://img262.imageshack.us/img262/6494/download007bi9.th.jpg[/IMG] I saved them to my desk top then enlarged them to look at them. I think this shows what your looking for. ]
http://mel-adjusted.zoints.com/ ![]() Weird - don't understand why the pics aren't showing up on your post?? Oh well - clicking on the links pulled up the images on imageshack. The 2nd pic showing the lower hose was pretty good for showing what I needed to see (I also saved and expanded it up a little). Eyballing my engine and chassis - ideally the hose would just come straight out of the WP inlet, then make a gradual curve ~90* to wind up going straight forward up along the side of the car. The overhang of the head and timing belt cover fouls this idea though, it really needs a formed hose to drop down a little and go under the timing cover - just as shown in your pics. That's good enough to invest in a new OEM lower hose. From there I'm just going to run Gates green-stripe hose up to the front of the chassis. Jeff ![]() ![]() Gimme some more explanation on your post. Factory front hose? Not following. Is that from a different part of the cooling system? Is that the standard lower hose just rotated on the pump inlet? That hose has some possibility - if it were rotated down and the S-bend were laying mostly flat. I only want to go a little higher than the WP inlet - the return hose the the water pump will run along the side/bottom of the chassis, from the radiator all the way to to water pump. Jeff ![]()
I had to go back and look at the pics I posted and your right, that is the top hose. Cool. I'm sure if you went into a parts house with the hose diameter you could come up with something.
http://mel-adjusted.zoints.com/ ![]() ![]() Does the body-lift kit you're using provide the necessary space for the radiator (or would it fit OK without the extra lift)? Can you show us some more details about how you're fitting the radiators? Supports/mounts, hose routing back to the engine, planned air-flow? Are you using the stock "front cut" Subaru radiator? What are the dimensions of this radiator? I gather you've found them to adequately cool the rear mounted Subaru engine? Sorry for all the questions. Your picture looks like a great layout and design that might be adaptable to other Subaru/buggy converts - on this side of the world! Jeff ![]() Beuty is in the eye of the beholder or in this case --the designer ![]() Does the body-lift kit you're using provide the necessary space for the radiator (or would it fit OK without the extra lift)?
planned air-flow?
Will post some more pics when its done ![]() Can't argue with that! Didn't mean to imply they look bad or anything! Still like the overall look of the buggy - very innovative over the manx clones. Cheers, Jeff Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
