My stock Subaru 2.2 with a 002 bus transmission I am running a 200mm (8") clutch. I first tried the stock clutch and the engine would easily over power it and it would slip. I then purchased a Kennedy StageII 2100# pressure plate and an EMPI Cushion Grip Disc. It hooks up well and has a good feel. At first the pedal was very heavy and I ended up breaking the clutch cable, it pulled out of the crimp on the pedal end of the cable. I thought it was a poor quality cable but I was wrong? The problem was the flex sleeve at the transmission was not on the tube that goes through the pan so it was binding. I put a new cable in and fitted everything together correctly and it feels like a new car and the pedal is easy to push now. The Kennedy StageII pressure plate and Cushion Grip Disc is a good combination.
Ross
MN
Lo Cash makes custom cables qauruteed for life he posts on the buggy site here check it out
![]() http://www.locashracing.org/products.html Jeff Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
