I build american vintage drag cars and I couldn't resist on this buggy. It sat outside in the rain so the cylinders are shot and as I took a head off, it's a 92.93 piston, which would make it an 1835 I think.
For some reason my picture isn't uploading.
Input exceeds maximum allowed size or is corrupted.
If you think this is a real error, you can inform the administrator. Please include the exact error message and the time of occurrence.
Are you trying to insert it while still making your message? If not, you should be able to insert it in the message after you have posted it, then go back and attach image. You might also need to shrink the size of the picture. I use the "paint" program in windows. I generally shrink them about 40%. Give that a try.
