Previous Next Up Topic Public / Dune Buggy Build Advice / stock carb 1600 dual port (933 hits)
By minivolks Date 2018-07-29 16:18
1972 carb wont idle anymore.   Cleaned it multiple times.  Engine is newly rebuilt, runs great.   Is it just possible carb is woreout?    I noticed butterfly at bottom of carb has worn into idle port.  That cant be good!!   This carb has always had an idle problem.
By Brad H 1498 Date 2018-08-03 04:13
IF the throttle shaft is that worn that it is starting to cut into the carb body the carb needs to be replaced
