Previous Next Up Topic Public / General Discussion / buggy lighting (2273 hits)
By Billy H 5032 Date 2017-10-24 17:13 Edited 2017-10-24 17:23
HI , I am having some lighting issues , I've been throwing money at this buggy since July , I am getting close to having it  back together . I have head lights, high and low , I have tail lights , I have brake lights. when I turn on my blinkers the front work like they are supposed too but all 4 of my rear lights blink at once . anyone have any ideas how I can fix this . also with the light switch off , I have brake lights , but front blinkers and all lights on the back blink at once .
By Ron S 3875 Date 2017-10-25 16:21
Based on the description, I would look at each and every ground connection for the lamp sockets.  I think you may have a bad ground(s) and getting ghosting grounds or feeds through other bulbs.  I see this a lot on older trailers where ground have worked loose from vibration, but fiberglass buggy's also lack a lot of grounding options.  This is most common with 1157 type bulbs or housings with a single wire ground.
By Billy H 5032 Date 2017-10-27 02:15
HI , thanks ill give that a good look o.ver
By Jeffrey P 655 Date 2017-10-27 14:23
The ground suggestion is a good one. Especially if the rear(s) blink more dimly.
Another issue could be wiring. Did it work before and this is a new issue?
If this is the first time it has been wired what kind and how many lights do you have in the rear? Why style turn signal switch?
