Previous Next Up Topic Public / Dune Buggy Build Advice / What is this? (2298 hits)
By Thomas B 2944 Date 2016-11-09 00:19
I mistakenly add this to the wrong forum topic Sorry.
Tom
Greetings All,
     On my 73-74 1600 crankcase there is a brass fitting type device on the the mounting flange. It has a white nylon inside and looks to be OEM installed. I do not remember of disconnecting anything from it, so I'm at a loss. If it were on a modern engine I would say it was the broken portion of a crank sensor of some sort. There is most likely someone in the "Buggy Bunch" that has seen this before.
Tom
Attachment: PB082599.jpg (133.5k)
Attachment: PB082602.jpg (210.4k)
Attachment: PB082603.jpg (224.3k)
By Thomas B 2944 Date 2016-11-09 11:12
Hi Jeff,
     Thanks for the info. When I looked at it I suspected in was some sort of a sensor. Its hard to beleive that in those years there was the beginning of "electronic controls". Reminds me of the wand that GM used for setting timing on their cars, I think in the late 70s to early 80s. I surfed on The Samba for the info but, not knowing what to call it, my search was hindered.
Thanks Again
Tom
