Greetings All,
On my 73-74 1600 crankcase there is a brass fitting type device on the the mounting flange. It has a white nylon inside and looks to be OEM installed. I do not remember of disconnecting anything from it, so I'm at a loss. If it were on a modern engine I would say it was the broken portion of a crank sensor of some sort. There is most likely someone in the "Buggy Bunch" that has seen this before. Tom Attachment: PB082599.jpg (133.5k)
Attachment: PB082602.jpg (210.4k)
Attachment: PB082603.jpg (224.3k)
