Previous Next Up Topic Public / General Discussion / Ball joints (3109 hits)
By minivolks Date 2016-09-08 16:51
What type/brand of ball joint is recommended for my buggy?  1972 kingpin.
By Jeffrey P 655 Date 2016-09-08 19:27
1972 Kingpin?
No kingpins on a 1972 and no ball joints on a kingpin.
By minivolks Date 2016-09-08 20:21 Edited 2016-09-08 20:42
Oh, sorry.  Is it called a beam?   Also, I have
Front End Adjusters For Ball Joint Front Ends, do I need the ball joints for lowered suspension?
I found ball joints on jbugs.
Has anyone ever just rebooted a ball joint?
By Jeffrey P 655 Date 2016-09-09 03:32
A kingpin front suspension is on pre 1966 (I think) chassis.  Ball joints came later.
If you have adjusters in the beam I would get the clearance ball joints like:
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D4192
If you already have lowered ball joints and they are in good shape you can reboot them:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D131%2D405%2D001%2DA4
By minivolks Date 2016-09-09 13:05
Great stuff, thank you!  Can you grease these? I don't see fitting in picture.
By Jeffrey P 655 Date 2016-09-09 13:43
Nope. No fittings. You can get a needle attachment for your grease gun and slide it in from the top if you feel its needed.
By minivolks Date 2016-09-09 16:49
Ok thanks,  Is it necessary to remove control arms when changing ball joints?
By Jeffrey P 655 Date 2016-09-09 20:59
Well they have to be pressed in and out so it could make it a heck of a lot easier.
