Previous Next Up Topic Public / General Discussion / fule pump rod (2841 hits)
By JACK 1467 Date 2015-06-22 23:43
how do you get the fule pump rod out , not able  to it,  I think it comes out with it Right ???
tried it all  did I miss something ,,,,,Help
By Jeffrey P 655 Date 2015-06-23 01:27
Rotate the engine until it pops up and then just slide it out.
By JACK 1467 Date 2015-06-24 00:04
no good tried all that it's gamed  in side . I was having some  stoped running  waited then started right up , so  thing it might be vaper lock so I took out the pump TO FIND the pin inside that's why it stoped running. what do I do.
do I need to get a new motor, Im beside myself.
By Jeffrey P 655 Date 2015-06-24 00:42
Spray some WD40 onto it. I have never...ever...ever...seen a stuck fuel pump pushrod.
Maybe its bent and wedged in the guide. If so then just lift the entire mount/guide off.
By JACK 1467 Date 2015-06-24 08:28
how do I do that .??? I"ll try to post photos
By JACK 1467 Date 2015-06-26 02:45
got it out , not bent ,  but the tip of it look's to rounded off, plus found some metal shavening in it and on the push  rod (brass) plus the thing that go's back in ( don't know the name to it )it do's not slid down like I see on u tube ,
some thing not right.
Good thing I got  a nice 1776, 67 vw dub dule carb  and trans for $1,000.
with a max body (going to sell)
so if some one might want it the frist $300. can have it . new pans, wind shield,all the parts  but the trans and motor.................
