Topic Public / Dune Buggy ID Help needed - X-Files / Just got it but not sure what it is any help would be great (4730 hits)
Just picked it up last weekend not sure what I got lol[img][/img]
could be the size or the type. you do need to add them After you post the message. at the bottom below your message will be some buttons to do several things to your post
Reply Edit Delete Attach ToDo Use the attach button and browse your computer for your picture. If it turns out to be too big, you can resize it using windows "paint" program. I generally go with 60% in each direction. Hope this helps
there got it to load any help would be great
Don't know what it is, but I'm kinda digging it. Like the roof. If the rear wheels were just a tad bit farther back, it would look even better. Good luck, and have fun.!
title says it a 1963 but vin# on title as far as online says its a 1967 also motor serial # is a 1967
