Previous Next Up Topic Public / Dune Buggy Build Advice / Case Advice (2729 hits)
By Brandon W 4263 Date 2014-12-19 18:25
I have a complete buggy and am starting a rebuild.
I dad the motor running a few years back and it ran fine up and down my 1/4 mile dead end road, but I want to make this thing street legal and decided it was best to completely go through the motor.
I have been reading that the H5 cases are weak. It would be great to get a little more HP than stock but it is equally important to try to stay near the budget on this. This will just be a summer toy, won't be drag racing or anything (the look on the face of a "sports car" owner getting passed by this would be pretty sweet though ;-) )
There are some decent hills in the area, and not having to crawl up them would be good too.
Don't have my plans set in stone, but I was thinking at the very least to go to 1600cc pistons, dual carb setup, electronic ignition and better exhaust.
Will the case be ok with a little more than stock HP?
By Jeffrey P 655 Date 2014-12-19 20:49
The case will be fine with slightly more than stock. Your plans are fine.
By ManxBug Date 2014-12-21 03:27
Buggies are very light. A stock 1600 can shock some classic sports cars. I ticked off an 80's Vette owner once.
By Brandon W 4263 Date 2015-01-05 15:10
Thanks guys!  Based on the replies I will keep with my plans to use 1600cc pistons, and continue to use the 1500cc heads.  I know the compression will go up a little, but sounds like I should be ok.
Trying to get this thing drive-able as inexpensively as possible and can determine desired upgrades after running it for a bit!
