Previous Next Up Topic Public / General Discussion / tin (3633 hits)
By rich p 4175 Date 2014-10-28 01:26
Is there any difference as far as thickness from OEM tin and after market tin-My motor is 69x77 and the tin I bought seems to long -any suggestions-Thanks Rich
By Brad H 1498 Date 2014-11-01 14:35
The new tins are horrible as far as quality, the metal is thinner and the stampings are often poor and poorly put together. If you have to trim them to fit, it's no big surprise. You might have also bought tin for a later motor and the 1200cc motor you're working on is a bit narrower. I've never seen new tin offered for a 40 horse, you likely have tin for a 15/1600 motor. How does it fit around the intake? If the hole is not tight to the intake flange you have later model tin.
By rich p 4175 Date 2014-11-25 15:18
I finally trimmed the tin to fit but there is got to be someplace to buy a thicker tin,this stuff sucks,It is installed and the only way I'd buy this cheap stuff is if I was  getting ready to unload.
By rich p 4175 Date 2014-11-25 15:59
Thanks Jeff I'll check it out-Rich
By Brad H 1498 Date 2014-11-26 12:42
The Scat tins are nice from what I've seen
