Previous Next Up Topic Public / Dune Buggy Build Advice / brakes brakes brakes (3445 hits)
By mark p 4106 Date 2014-08-06 15:17
I am now replacing all brake shoes and  cylinders and need some help to work out if I can convert to discs?
I believe it has already been changed to take  a set of cragers on a chevy pattern
the bug itself is a 1975 but need help as to how to determine what conversion has been done on the drums to work out what I need to change to discs?  any help or advice please
By Jeffrey P 655 Date 2014-08-06 16:56 Edited 2014-08-07 01:58
Yes you can convert to discs.
A 1975 Bug would have had a 4 bolt pattern. If you are running Cragars with a 5 bolt Chevy pattern you likely have adapters bolted to the stock VW 4 lug drums.
Many many places have disc brake conversion kits. Here is just one example:
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D4121
By mark p 4106 Date 2014-08-07 01:13
Thanks but that's what's confusing me the drums have nothing bolted to them they are actually 5 bolt drums all round? Will post a pic soon if it helps
By Jeffrey P 655 Date 2014-08-07 01:57
Well then they could have been blanks that were drilled for a Chevy pattern.
By mark p 4106 Date 2014-08-07 23:10
Yeah could be I will look into it more
Thanks for the help
