Previous Next Up Topic Public / Dune Buggy Build Advice / E-Brake Bracket (2473 hits)
By Richard S 4103 Date 2014-07-04 06:38
Hey all,
First timer rookie here, quick question, does the E-Brake support bracket that the handle attaches to come up from the bottom up through the tunnel or does it get bolt right on the top of the tunnel? I have a fiberglass pan and a berrien/Acme Nostalgia chassis, also does the shift rod guide just bolt to the fiberglass tunnel or do I need to install a shifter box under the tunnel. It just seems like the fiberglass tunnel would not support the shifter very well.
By Brad H 1498 Date 2014-07-05 00:49
I've never seen the Berrien floors so can't speak to their strength. But I would definitely weld these 2 pieces into the chassis. They are both high stress areas and I don't think hte glass will hold up at all. Having the park brake bracket coming up from enderneath will let you make a smaller hole in hte tunnel and give you a cleaner install.
By Richard S 4103 Date 2014-07-05 04:04
Thanks Brad, I agree, I will fabricating some mounts.
