Previous Next Up Topic Engines / Corvair Power / To start or not to start 140 hp Corvair engine on stand (7141 hits)
By Kellison Jim Date 2013-09-01 02:27
I've done it a number of times with my VW engine but was wondering if it would be safe to start my 140 hp Vair engine on the engine stand. I'm concerned with the added weight and torque.
By Lloyd B 2301 Date 2013-09-01 05:57
How handy are you at putting together a Wooden Stand?   It might be a day or two but I could probably get a picture of the one I have my 140 on.
Lloyd
By Kellison Jim Date 2013-09-02 02:00
Thanks Lloyd, looking forward to your photo.
By ManxRob Date 2013-09-02 05:11
That is a fine looking 140!
I don't know what your test stand is like, but as long as it doesn't feel like it's going to tip over it should be fine.
I test-ran my Corvair engines adapted to VW transmissions while they were sitting on a small wood moving dolly. I wanted to make sure the starter adapter and bushing were properly seated, and the engine and transmission oil seals were functioning before installing them to a bodied pan.  The test run on the dolly worked just fine. Just make sure you aren't supporting the weight on the headers or pushrod tubes.
Rob
By Lloyd B 2301 Date 2013-09-25 16:29
Jim, sorry for not getting back with you, Issues at home.   Do you still need those pictures or did you go with the wood dolly?   Just let me know.
