Previous Next Up Topic Public / Dune Buggy Build Advice / intermediate flange (1922 hits)
By andrew s 1965 Date 2013-03-06 00:15
Question
I painted engine and took most everything off and found the intermediate flange ( plastic piece between fuel pump and case) was broken down inside the block. Piece is lodge in there pretty good and i made a lame atempt to pull out with a pic and it did not come out ( was afraid i would break pic) so i might need to get a puller or bend a screwdriver.
My question is does it need to come out and be replaced our can i put it back together as two pieces?
If it does not matter and will not mess things up i would rather leave it alone
This part was broken when i took apart.
By Jeffrey P 655 Date 2013-03-06 03:32
Most people run a big tap into it and then thread a bolt in to grab a hold of and yank it out.
Yes...you should replace it. It may crumble if left in there and then you could have some trouble.
Its a pretty common thing.
By Brad H 1498 Date 2013-03-06 19:04
Geet it out for sure, it could break up and go into hte cam gear and possibly break your cam, or  plug up an oil galley
