Previous Next Up Topic Engines / Corvair Power / Push rod tube O-rings (4149 hits)
By Rick M 333 Date 2012-09-17 18:32
How hard are these to change, really? In the factory manual it looks like, and described as, generally pulling the tubes through the heads, changing the seals, and re-setting them back. Is it really that easy?
By Gary F 2793 Date 2012-09-17 21:40
it's easy. just make sure to gap everything properly and put everything back in the same location.
By ManxcloneVair 3408 Date 2012-09-17 21:45
Yes, they are easy to do. Just do one at a time. Re-torque after each one! Clkark's Corvair has some great how-tos. Check out their site. I used the viton "O" rings and some silicone lube to install. Runs great. Let us know how you make out!
