Previous Next Up Topic Public / Dune Buggy Classifieds / Meyers Manx (4025 hits)
By ManxRob Date 2012-05-02 16:01
Not Mine:
http://cleveland.craigslist.org/cto/2898899008.html
Meyers Manx Dune Buggy - $12500 (Parma)
Date: 2012-03-22, 6:51PM EDT
Reply to: see below [Errors when replying to ads?]
A wonderful authentic Meyers Manx
Apx. 920 miles since completed.
One of the finest buggies in the country.
For hundreds of photos and a complete description, go to the builders web site @ http://www.vdubn.com/dunebuggys/Manx/index.htm
A partial feature list.
4 wheel 11" disc brakes with rear E-brake
Pan, suspension, and roll cage completely powder coated
Intake Manifold and Exaust header completely ceramic coated
4 point 3" harness with cam-lock latches
6 Point roll cage
2088cc Engine (9:1 Compression)
Demello 78.4 forged crank
92mm Forged pistons
CB Performance 5.4" H-Beam Chromoly rods
44mm X 37mm Heads (Ported and Polished, Match Ported to Gene Berg intake manafolds)
Dual Delorto 40 DRLA Carbs
Gene Berg Linkage
CB Performance AS41 Case
Pertronix Electronic ignition (Pertronix Ignition Coil)
Pertronix flame thrower Ignition wires
High volume melling oil pump
Scat C35 cam
Autocraft 1.25:1 rocker/Shafts with needle bearings
12 lb Lightened/Balanced Flywheel
5.5 lb. Equalizer Pully
Pistons, Rods, Crank, Flywheel, Pressure plate all balanced by Demello Machine
Torquethrust 2 (American Racing) Wheels (15X10 rear, 15X6 front)
Dunlop P8000 VR Rated tires (245VR50-15 Rear, 195VR50-15 front)
Side pods glassed into the body
AutoMeter Ultralite Guages, Speedo, and Tach
All stainless steel fasteners
IRS rear conversion
1971 002 Bus transmission with 091 differential, bus-into-bug nosecone conversion,
Super beetle mainshaft, welded hubs, H.D. cross shaft, 4.57:1 aftermarket Ring and Pinion, stock gears.
Hydraulic clutch with heavy duty pressure plate and 3 puck disc
2 Infinity 5" Co-Ax speakers in the back, 2 Infinity 6" speakers with seperate tweeters in the fron kick panels.
Phoenix Gold 500.4 amplifier, Kenwood MP3 player with hideaway/detachable face and remote
JL Audio 10" SubWoofer
Full Custom interior with leather shift and E-brake boots, embossed MANX monogram in rear deck,
Custom tweed seat covers and full custom console.
See all the pictures on the website, and call me @ 440-821-xxxx (George) Anytime up to midnight
