I have a frame designed for a Corvair late model suspension (65-69). Some have told me it is a Con-Ferr frame or a frame from JC Whitney. I'm not sure which it is, but it is very similar to one we had in a previous buggy that we built in 1971 and bought the frame from JC Whitney (Warshawski Co.). The question I have is about the brake and clutch pedals to use with this frame.It has two shafts mounted horizontally on the frame for the brake and clutch pedals. The brake pedal shaft has a flange mounted to the front of it for the master cylinder. A Corvair or early Chevy brake cylinder will bolt up to the flange. A Corvair pedal will slide on the shaft, but the Corvair pedal usually mounts and swivels from the top, not the bottom. It appears the angle for the pedals is wrong. Does anyone know what types of pedals were designed to work with this frame?
thanks, Chuck ![]() Jay ![]() Jay Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
