'Vair autos were just standard GM Powerglide. Shift pattern from the top would have been R-N-D-L. There is no park position, so just make sure it's in neutral!! See here for some basic info: http://en.wikipedia.org/wiki/Corvair_Powerglide
As far as the shifter is concerned, I believe that is a stock shifter that would have been mounted in the Corvair dash. I'm not sure what else you could use to actuate the transmission. I have little experience with auto Corvairs. What size is the cable sheath? Jay Jay ![]() Does your front tunnel look like this? ![]() I suspect not, but want to ask. It looks like you have a Corvair front suspension on the car. Thanks, Jay See.... I have the ManxVair. It was a joint venture between Meyers and ConFerr (out of California). ConFerr was to manufacture a chassis to accept the Corvair front and rear... basically a buggy kit for using a Corvair as a donor. Meyers had to make special bodies to fit the square tunnel as well as to allow the rear suspension to fit. For that reason, the rear wheel tubs had the extra bumpout to allow for the full height Corvair rear spring and shock. Somewhere after ConFerr began manufacturing their chassis for the ManxVair, there was a company out there that copied the ConFerr frame, however they made a little "improvement" to the chassis. They allowed the rear coil from the 'Vair to sit below the rear tub. Because of this, no special fiberglass body was needed. They also filled the square tunnel with the VW type slope in the front. I suspect they did this design change to accept any fiberglass body by having the builder cut the rear coils down in height. It appears from your photo than they allowed stock shocks, but simply tipping them back where they attach at the top. I've only seen one other buggy like yours. It was a green one offered on Ebay not too long ago. In the beginning, the link was sent to me as a ManxVair, but I determined it was NOT a ManxVair. It was a Manx on this copied and improved chassis. I wish I could remember the manufacturer of the chassis. I'll have a look for it and see if I can find it. It looks the SAME as the ManxVair chassis in the picture if I remember correctly. Your body is not a Manx, so it was another clue that you may have had this chassis. IF you ever take this thing apart, please document it completely with photos! Thanks, Jay also need some help trying to locate a automatic shifter for this it wants to come out of gear .the lugs on shifter are kind of worn I think that's the problem. and jay I sure will take lots of pictures when I rebuild it. probably start around October or so. Here's a page from Clark's Corvair Parts that shows both the early and late style shifters. http://www.corvair.com/user-cgi/catalog.cgi?function=fetch&find_page=NOS-31 Hope this helps. Jay Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill | ||
