![]() i dont want a regular hardtop 1. because it makes mine a two seater 2. i dont like the way the 4 seater hardtops look 3. havnt been able to find one to fit a sand shark because of the droopy rearend im thinking i can cut this one down and make a fiberglass bamini? bakini? whatever top just from the windsheild to the roll bar. anyone done this? the only downside i see is my passengers cant grab around the roll bar to hang on. most of the time if we are gettin a little nuts (ie..tough hill in the woods) the wives and kids bail out and watch from the side simlar to the canvas but fiberglass and just attached to the roll bar the pic isnt mine but similar to this canvas one ![]()
Why not just make a canvas one or if you want a hard top build your own instead of cutting up a roof. It will probably be as much work to retrofit something as to build new. I've seen all sorts of tops, there is no right or wrong. Build it to what YOU need....
brad ![]()
i would build a canvas one. this way if you dont need it you can take it off and fold it up and stick it in your buggy with a fiberglass one you have to keep it on or off.
you could always build a cloth top the way you want it to look, then fiberglass over it. matt and Batt ,not just resin
