![]() I was looking for something other than steel for corrosion resistance and easier servicing down the road (like when I upgrade to that STI turbo.... ![]() I also wanted something that wouldn't turn to rust in the first few months of operation. I purchased some metric ARP SS bolts to use for this - but then realized the one bolt hole below the turbo outlet doesn't have any room to use anything other than a hex head fastener in that position. No way to get a wrench on the 12-point! So Tom - I've decided to switch to the Monel 400 hex head bolts for bolting turbo to header. These are well matched to the expansion characteristics of steel, but with high temperature and corrosion resistance of stainless. There was just one thing I didn't like about them - I can only find them in SAE thread sizes. The closest is 3/8" (vs. 10mm) - which is only about 0.015" difference. Normally that wouldn't be too big a deal - but the bolts align the turbo with header, and you don't want any off-set/blockage where the two meet. Add in the bolt hole clearance and one could potentially have some power robbing mis-alignment during assembly. What was needed is some way to "bush" the 3/8" bolts to fill the holes. I considered various tube type bushings, but trying to make something such thin wall - out of stainless steel would be problematic. Then it dawned on me - which not use shim stock! I located some 0.005" thick stock - which can be cut with good scissors. A couple loops around a bolt formed a great shim to take up the slack - like an alignment bushing! Problem solved! I do plan to keep the outlet side bolts the original ARP SS, I still think they may work OK when torqued down well. Man, I'm going stir-crazy trying to figure out things to figure out while I can't do any physical work on the buggy! Jeff ![]()
Manx Club #1030, CVA, RBC, SCCA ![]() So one question - did you do anything to "lock" the fastener and keep it from loosening? I'm planning on the bolts and nuts (about $15 for 3 sets - sheesh!), debating the lock washers, another $12. All this for 3 lousy bolts! Jeff ![]() I had ss lock washers on mine initially which may have failed from heating/cooling cycles. Two of the three nuts loosened completely off. Thankfully, I installed the bolts head up, so they remained in the flange holding alignment at a minimum. If my current fix doesn't hold, I'm going to safety wire them. Jay ![]()
Nickel high temp never sieze. Also forever we have used brass nuts to stop siezing on exhaust studs.
![]() Where do you find the copper coated nuts that fit the thread on the exhaust studs (at the heads)? I could not find any for that thread pitch. I bought some new ones from Subaru, but they appear to be standard steel and are not copper coated. Jeff Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
