Previous Next Up Topic Engines / Subbug - Subaru Power / Subaru EG33 SVX Parts for sale (4227 hits)
By Paul Moran (DBA Architect) Date 2008-12-10 03:17 Edited 2008-12-10 03:22
The engine I just picked up has a bad crank - the keyhole is mangled so the parts are up for sale.  Not sure if any of these will cross over to an EJ style motor.
I only opened it up as far as the timing belt covers and valve covers - anything deeper I'll have to check if it is worth selling.
For Sale:
valve covers
injectors
heads
pistons
connecting rods
oil pump
water pump
side belt covers (center is broken)
cams
water manifold
alternator bracket
cast exhaust manifolds (just the parts that attach to the block)
intake manifold - some small electronic parts on this have broken nibs
sensors - except knock sensors that are cracked
Cam timing belt pulleys/cam gears
Parts that were missing/destroyed and hence not for sale:
Alternator
MAF/plastic intake pieces
crank pulley
center timing belt pulley
timing belt
I have the entire harness/computer/electronic modules.  I will probably hold on to this for a future conversion but would consider selling it.
I'll put this stuff on Craig's List or something if I don't get takers here but I'd rather sell it to a Subbug member.
