Previous Next Up Topic Public / Dune Buggy ID Help needed - X-Files / Manx Like Buggy needs ID... (3812 hits)
By John S 2 Date 2006-05-18 03:27
Ok I have been thru your fabulous site over 20 times....I've got a Manx clone...it looks exactly like a Manx:
Classic body style
Classic hood ( no ridges, bumps, scoops, etc)
Separate fiberglas dash
Has space for battery and 'spare tire"
No data plate (or holes)
Rear license area looks like a Manx
No under side panel  "tubes"
Correct Manx style windshield (groove at the front)
The pan it was on was originally titled in Michigan
I can't find a similar body anywhere on your site...could it be a Manx without the tubes??
Dizzyspots@aol.com
By yellermanx y 25 Date 2006-05-18 14:47
I'm not aware of any Manxes built without the tube down the side.  The Manx also had an ABS (plastic) dash with a steel bracket behind it.  The Manx II and possible a couple of the Manx Is had a fiberglass dash, but it was one piece with the hood.  The Manx club does however offer a fiberglass replacement dash now.  Keep in mind there were thousands of copies.
