Previous Next Up Topic Engines / Subbug - Subaru Power / Plastic inlet and air cleaner location (2777 hits)
By dunelimo Date 2008-01-15 06:07
For a while I have been scratching my head about the plastic inlet tube and air cleaner location for my 2.5 quad cam which has a remote air flow sensor in the plastic tube not on the manifold so the original tube must be retained, a while back I reversed the inlet manifold which stopped me from cutting the body for clearance which solved one problem but the air cleaner sits in a bad location well past the engine even thow I shortened the plastic tube which helped but it was still not good, I have now made some reverse/directional throttle body adapters which lines up the plastic tube and aircleaner much better--another headache solved
Here are some pic's of how the aircleaner sits and how it will sit after the adapter is fitted
By Mel Adjusted Date 2008-01-17 02:31
Thanks for this post. You solved another of my problems.
By dunelimo Date 2008-02-05 22:31
Here the throttle body has unwanted stuff remove and a VW solex arm welded onto and exiting blade to eccept a standard throttle cable, the 'radius ' of the new arm is also matched to the solex carbi arm 'radius' so there is no mismatch between it and the standard gas foot pedal which I will be useing, I want to make sure I can obtain WOT :-)
