Previous Next Up Topic Engines / Subbug - Subaru Power / Clutch disc and pressure plate (4362 hits)
By Ross C 356 Date 2007-08-12 03:48 Edited 2007-08-12 19:57
My stock Subaru 2.2 with a 002 bus transmission I am running a 200mm (8") clutch.  I first tried the stock clutch and the engine would easily over power it and it would slip.  I then purchased a Kennedy StageII 2100# pressure plate and an EMPI Cushion Grip Disc.  It hooks up well and has a good feel.  At first the pedal was very heavy and I ended up breaking the clutch cable, it pulled out of the crimp on the pedal end of the cable.  I thought it was a poor quality cable but I was wrong?  The problem was the flex sleeve at the transmission was not on the tube that goes through the pan so it was binding.  I put a new cable in and fitted everything together correctly and it feels like a new car and the pedal is easy to push now.  The Kennedy StageII pressure plate and Cushion Grip Disc is a good combination.
Ross
MN
By michael c #69 Date 2007-08-12 14:03
Lo Cash  makes custom cables qauruteed for life he posts on the buggy site here check it out
By @Jeff GS Date 2007-08-13 10:50
I was going to mention Lo Cash too - couldn't remember where I'd seen these.
http://www.locashracing.org/products.html
