Previous Next Up Topic Public / General Discussion / G down (9606 hits)
By JACK 1467 Date 2016-04-07 02:54 Edited 2016-04-07 02:56
has some one ever got the G down on your vw
I payed for a 1641` scat vw eng and to make it look better I got a G down ex
By Brad H 1498 Date 2016-04-08 01:44
I've heard varying reviews about them but I think they are pretty col. I'd like to run one on my bounty hunter. Let me know what you think of the sound.
By JACK 1467 Date 2016-05-18 01:06
20160517_185950_resized
By Brad H 1498 Date 2016-05-18 01:30
Nothing comes up Jim, Just a bunch of numbers
By Lloyd B 2301 Date 2016-05-18 19:23
Jack, do a resize in Paint and then bring it into your post from computer after you have made the post.  If that does not work, Send the pic to me an I will try to post for you.  I think you still have my email?
Lloyd
By JACK 1467 Date 2016-05-19 01:56
send me a pm ......PS
how can I put a 12volt system in a 6 volt  trans........................
By Jeffrey P 655 Date 2016-05-19 13:56
With a grinder and some caution.
By Lloyd B 2301 Date 2016-05-20 09:32
lets see if this works
By JACK 1467 Date 2016-05-21 18:53
well I got it  ...hope if it starts with all that Grinding ...
By JACK 1467 Date 2016-05-24 02:18
well with all that grinding no deal....... have to get a new 12 volt trans ..............it  fit but some thing is hanging up
By JACK 1467 Date 2016-07-21 01:31
well I got the G Down pipes , well let me start with this I waited not 4 week not 6weeks but 4 monthes to get it
then when I got it  it was missing stuff I had to go to the parts store .to install it .let start by saying it was not easy to install I had to cut up and re fit it to go on,ended up striping a stud trying to put it on mounting starp in the wrong place had to cut them off and redo.what a mess it was .........................
By Michael T 1299 Date 2016-07-22 21:10
Still having trouble with the 6V to 12V conversion? Some things that occurred to me are:
Are you using a 12V starter?
Did you put in the correct 12V to 6v conversion starter bushing?
If you don't want to mess with bushings just get an automatic stick shift starter. It is self supported and a bit more powerful as well.
The 6V to 12V conversion has been done countless times it should work for you too.
By JACK 1467 Date 2016-07-30 02:29
had  to get a new trans ....... new trans new motor new batt,
new stater, new bearings , new seals, All new, stuff
