Previous Next Up Topic Public / General Discussion / new empi bolt on front disc brakes driver side chatter (3038 hits)
By stressfree s 2527 Date 2014-03-08 17:12
hi guys long time busy anyway put bolt on disc on front of my t bucket buggy.stops good. some times at slow speed it chatters on drivers side. now there new no miles on it. is it just grabbing and have to wear in.not much to check.it doesnt do it all the time.
By Brad H 1498 Date 2014-03-08 22:02
Are the brackets stamped steel or forged. If they are stamped steel make sure they are perfectly parrallel to the rotors. MY rear ones were off just slightly and I would get a groaning noise at low speed. Also you could put some good RTV on the backs of the pads to bond them to the pistons and that helps quiet them up also. DON"T use a lot, just a light coat where the piston contacts the pad. After you apply it put the brakes back together and step on the brakes lightly to set the pads and let cure for a while before driving. Make sure all the mounting hardware is propperly torqued also.
By stressfree s 2527 Date 2014-03-09 14:20
there economy empi stamped they do stop good not much to see might try the rtv cement.ill wait till i wear them in first could stll be new and grabbing.thanks.
