Check you king and link pins or balljoints and tie rod ends. I've seen you symtoms before and it's always a loose front end part. I had a 56 Beetle that would start and stop shaking on the highway, turned out to be a loose king pin.
Make sure the arm on your steering box is tight as well.
Thanks for following me Jim, I havent driven mine in a few days since the wife is out of town have no one to tow me if I break down still working the bugs out of this thing. If you look at the dash above the steering wheel you just see it but I still need to do some more investigateing on this I hope I can find a means to the end to make driveing more enjoying. V
