![]() Here's my configuration - but maybe others may want to post their own specifics and msq file that is working for them? JDM EJ20 (typical EBay single turbo Legacy motor) WRX TD04 turbo, air-air intercooler Custom exhaust and intake (to fit the chassis) MS2 V3.0 Extra EDIS ignition system with custom mounted 60-1 toothed wheel Boost controller (DIY Autotune parts) wired through Q16 GM stepper IAC valve Relay board Innovate LC1 wideband O2 sensor I'm mostly looking for ignition, VE and AFR table values I can plug into my start up msq file to get things started (after all these years!). Warm-up and boost controller settings would be a bonus! ![]() Thanks, Jeff ![]()
EMPI Imp 1002 ('69)/Subaru EJ20 Turbo/LinkPlus ECU ![]()
Manx Club #1030, CVA, RBC, SCCA ![]() Thanks again Paul for the MS files. Haven't yet had a chance to dig into them (long work days lately), but I should be able to this weekend. I'll post up screen shots of the maps when I get it figured out. Jeff
Hey Tom,
Would you be so kind to email me your map that you are running using the Stinger. I too have the stinger but am running an EJ20t STI and not the 2.5 liter that I think you have, but the map would still be more info for me to look off of etc as the closest dyno to me is 4hrs away. It would be a huge help. I would be interested in what your configuration is, what turbo, what psi, what injectors, etc if you know. I think I remember reading that you had it dynoed?? My email is badvw68@hotmail.com It would be much appreciated. Thanks, Alden
Mattoon Illinois
www.phillipsprocycle.com ![]() [img] ![]() [img] ![]()
Thanks Tom, I got your email. This should help out considerably to look off of and compare my results with. I will post my findings within the next few months.
Thanks again, Alden
Mattoon Illinois
Manx Club #1030, CVA, RBC, SCCA Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
