I have no idea what year motor I have. The only thing I can tell is that it is a Type 3, the distributer PN# 0 231 137 011, and the carb PN# 34 Pict-3. I want to just put a new distributer that's modified but I don't want to buy the wrong one due to the fact no one will allow you to return electrical components. Any help would be appreciated.
There are books that detail the year of the engines from the VIN number. The VW manual shoudl help you with this. The VIN number would be important to determine the info you need.
Just as a starting note..... Also, if you could post a photo of the engine from the rear....? ![]() http://www.thesamba.com/vw/classifieds/detail.php?id=682483 I haven't used them, I run a Accufire ignition on my buggy with a 009. If you look at the table I listed below your distributor uses the same points and condenser as the the 0 231 147 002 - 3BOS4V2, The conversion kit should be the same. DISTRIBUTOR POINTS CONDENSER CAP ROTOR 0 231 139 002 01 006 02 006 03 037 04 010 0 231 147 002 01 009 02 007 03 001 04 006 0 231 181 003 01 011 02 074 03 010 04 016/033 0 231 112 005 01 003 02 170 03 019 04 008 0 231 137 005 01 009 02 007 03 001 04 006 0 231 139 005 01 006 02 006 03 037 04 010 0 231 168 005 01 011 02 074 03 010 04 016/033 0 231 173 005 01 011 02 054 03 010 04 016/033 0 231 181 005 01 011 02 074 03 010 04 016/033 0 231 139 006 01 006 02 006 03 037 04 010 0 231 173 007 01 011 02 054 03 010 04 016/033 0 237 022 009 N/A N/A 03 010 04 038 0 231 137 009 01 009* 02 007/069² 03 001 04 006 0 231 173 009 01 011 02 054 03 010 04 016/033 0 231 178 009 01 030/011 02 086 03 010 04 033 0 231 137 010 01 009* 02 007/069² 03 001 04 006 0 231 173 010 01 011 02 054 03 010 04 016/033 0 231 137 011 01 009 02 007/069² 03 001 04 006 0 231 167 012 01 011 02 054 03 010 04 033 0 231 181 012 01 011 02 074 03 010 04 016/033 0 231 181 014 01 011 02 074 03 010 04 016/033 0 231 115 020 01 003 02 170 03 019 04 008 0 231 137 021 01 013 02 007/069² 03 001 04 006 0 231 022 025 N/A N/A 03 010 04 038 0 231 176 028 01 011 02 074 03 010 04 033 0 231 167 029 01 011 02 039 03 010 04 033 0 231 137 031 01 013 02 007/069² 03 001 04 006 0 231 176 033 01 011 02 074 03 010 04 033 0 231 170 034 01 011 02 074 03 010 04 033 0 231 170 034MEX 01 011 02 054 03 010 04 033 0 231 137 035 01 013 02 007/069² 03 010 04 033 0 231 137 036 01 013 02 007/069² 03 010 04 033 0 231 170 036 01 011 02 074 03 010 04 033 0 231 137 039 01 013 02 007 03 010 04 033 0 231 115 040 01 003 02 170 03 019 04 008 0 231 176 044 01 011 02 074 O3 010 04 033 0 237 022 045 N/A N/A 03 010 04 038 0 231 176 048 01 011 02 074 03 010 04 016/033 0 231 167 049 01 011 02 054 03 010 04 033 0 231 115 056 01 011 02 021/039 03 001 04 006 0 231 167 053 01 011 02 054 03 010 04 033 0 231 176 053 01 011 02 074 03 010 04 033 0 231 167 055 01 011 02 054 03 010 04 033 0 231 167 070 01 011 02 054 03 010 04 033 0 231 115 078 01 011 02 021/039 03 010 04 033 0 231 170 093 01 011 02 074 03 010 04 033 0 231 146 101 01 011 02 039 03 010 04 033 * if breaker plate has been replaced with 1 237 110 139, use 01 013 ² less-expensive alternate (mandatory with air conditioning)
Here is a photo of the motor. I still haven't located the VIN number.
I have looked all over the engine and I don't see the VIN. Where is it?
VIN should be in the same place as a type 1 engine, but it's covered by the cooling fan housing on your type 3 engine.
The engiine number on aa T3 is stamped in the top of the case along the seam of the case halves, not on the front of the case. If there is no number there it could be an replacement engine. The engine in the picture is a 1500cc single port from a pre-67 Type 3. In 67 they went ot dual ports and dual carbs.
brad Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
