In the Empi catalog it shows that VDO makes stud mounting kits for 2 1/16 and 3 1/8in gauges. I don't know if they would work for your setup.
I have used hose clamps to hold gauges in panels before that where held in place with a rubber ring in dash they came out of.
Stud kit won't work, no holes inthe gauges to put them in. What about a thick rubber O-ring or 2 slid over the back of the gauge? You could always use some RTV to set them in.
Gauge panel is out. so the suggestions of O-rings, clamps, RTV, will all work, one other suggestion, Hot Melt Glue gun. Hot Glue comes in many colors including clear, couple of dabs on lip before you set gauge in panel, then several more on back side, should hold for many years.
Just my 1/5th of a dime. Lloyd ![]()
