Previous Next Up Topic Public / Dune Buggy Build Showcase / kenny U 2150 new frame for Sportsman buggy (4800 hits)
By Kenny U 2150 Date 2010-12-19 17:19
Hello I finally started building my frame. It will be a street/offroad buggy. It will have 2x3 rear trailing arms and a 6 inch wider front beam. Unsure of what motor i will use but it will have a bus transaxle. I still need to make some more brackets and design a roll cage. I will post more pictures in the process of building. Thanks for looking!
By Brad H 1498 Date 2010-12-21 16:34
Is you front beam tilted forward at the top? Caster might be an issue or are you cranking up the front end a lot?
By Kenny U 2150 Date 2010-12-21 18:07 Edited 2010-12-21 18:54
The picture looks a little decieving . I do have the front tubes angled down. the beam is sitting slightly back. It has longer trailing arms and king kong spindles This is my transition from always having off road and sand  rail buggies. I have had a lot of buggies over the past 30 years, But this build has me fired up like its my first one! Its nice to have DBA to look at other builds and share your own. I will add a picture of my last sand rail.  Thanks Kenny
