Previous Next Up Topic Public / Dune Buggy Build Advice / I'm buying plugwires????? (3954 hits)
By Dave C 77 Date 2006-12-31 04:12 Edited 2007-01-02 13:47
Im buying plugwires for a 94mm piston dual port 40 dellortos  1996 vw engine What are the best spark for the buck???? Bosch plugs ok any other suggestion??/
thanks Dave
By Sandsurfer Date 2006-12-31 13:50 Edited 2007-01-02 13:47
I always run original Bosch (gray) wires. The connectors seem to fit the best and the seals at the fan shroud seal better then the heavy rubber ones on most aftermarket wire sets.
Jerry...
By Bob E #19 Date 2007-01-03 17:50
Use the original Bosch and ignore all of the gee wizz solid wire, silicone jacketed, 8mm or what ever snake oil junk that exist out there, , ,  and you will never be sorry.
Boston Bob E.
Boston Bob E
www.bimelliott.com - www.the-bug-club.com - www.deserterownersgroup.org
By Dave C 77 Date 2007-01-05 03:23
THANK YOU VERY MUCH BOSCH IT IS
