Previous Next Up Topic Public / Dune Buggy Build Advice / is a holley 2100 the same as a holley bug spray? (7758 hits)
By Jake S Date 2009-08-02 17:31
i need to buy a kit for my holley 2100 carb but sinces its really old because it was used on the old flat head 8s i can't find cheap kits for it but i can find cheap holley bugspray and the kits/ carb looks the same will it work? going out to az to work on my buggy soon and i forgot to look this up so need this info fast pls!
By Jake S Date 2009-08-03 20:29
ill let you al no if the kit works for a bugspray on a 2100. but still dont no if it is a bugspray...
By Jeff GS Date 2009-08-03 22:06
I don't know if the carbs are the same - but you should be able to find Bugspray rebuild kits with a little Google searching.  Maybe the same for your 2100 carb.
By Jake S Date 2009-08-04 01:28
i can find bugspray ones but 2100s hard to find and cost alot
By Jeff GS Date 2009-08-04 10:59
Have you checked Speedway?  I know they have a pretty big selection of flat-head engine stuff in their catalog.  As stuff get rare, it gets more expensive.  You might poke around and try locating a flat-head message board, see what they've come up with.
By Jake S Date 2009-08-07 00:00
okay ty
