![]() For reference - this is going on a megasquirted Suby turbo engine. So the end connections are the "easy" part (TB & IC). Now thinking - what else needs to be plumbed into this tube? So far I've got: Blow off valve connection - 1" hose connection (Jay - I know you recommended plumbing this off the intercooler, but I'm not doing any more cutting/welding on the IC! There's just enough room underneath for a BOV with careful planning.) And that's about it? What about any sensors? MAT? This sensor looks like about a 3/8" pipe fitting (standard GM sensor) Anything else? Now is the time to begin planning for this stuff, so I can figure out the hose routing and general placement of whatever needs to go on there. Any vacuum/pressure tube fittings? Figured I'd come of the intake manifold plenum on top for general vacuum/pressure sensing (MAP connection, FPR, cockpit boost gauge & BOV?). The turbo has an integral tube fitting in the outlet port that looks ideal for connecting directly to the wastegate. I can always fit a manual boost controller later if I want to "tweak" this up a little. Anything else I'm missing? Jeff ![]() The BOV will likely come off the turbo housing and possibly be routed via a solenoid boost controller, but all that is separate from the plumbing you are discussing. That's all I can think of at the moment. Jeff, you put the BOV where YOU are going to be happy with it! ![]() 10 July 09 EDIT: I typed bad info here, so I'm editing it out so other people who read this don't get confused. Jay ![]() Thought the BOV needed to see vacuum at the sensing line in order to open? At least everything I've read indicates so??? The wastegate, OTOH, needs to see that boost signal to operate properly! I'm going to route the BOV "flow" sides to the tube we're discussing and to the intake tube upstream of the turbo (between turbo and air filter). Trying to keep all the hissing and popping to a minimum while driving! Thanks Jay! Jeff ![]() ![]() I originally typed BOV location and re-read your post. I realized you were talking sensing line, and In changing my text all around apparently I confused myself. I'm sorry I confused you. You were thinking correctly all along. My apologies. I'm going to go edit my post so it doesn't confuse more people that read it. Jay ![]() Going to measure all the fitting sizes today, as I've noted there are at least 2 or 3 different diameter nipples on the intake manifold, turbo, wastegate, FPR, Megasquirt MPS, and the BOV, etc... Time to begin figuring out what size hoses I need to get. Back to the intake tube, so for right now I'm planning fittings for the BOV (1" hose connection), the MAT sensor (pipe fitting), and probably go ahead and put in a spare 1/8" female NPT to have "just in case" I want to use it for pressure sensing later on. Going to do some finish cutting on the aluminum tube sections today, then begin re-fitting the body back down on the chassis (will need more clearancing around the turbo and intercooler). So on a somewhat related topic - the cockpit boost gauge: What is considered to be the correct size tubing to run from the engine - all the way up to the cockpit/dash for the boost gauge? 1/8" seems to be a bit small for good gauge response? Thinking along the lines of running a 3/16" metal line for the longest section (inside the center tunnel), connected at either end to flexible hoses to gauge and engine. Jeff
1/16" should be fine Jeff, I'm running 10' of vac line off a tee at the ECU port which is 6' from the intake manifold port and it works great. Just make sure you use quality silicon vacuum hose.
Terry ![]() On to other things: I have 1/8" plastic line run from the manifold through the tunnel forward of the bulkhead, out the tunnel, up the front outside of the bulkhead then back to the gauge in my dash. I was thinking along the same lines as you wondering if it would be too small. The gauge response seems just fine, but now I'm wondering if I shouldn't feed it with a larger diameter hose the length of the tunnel for a trial and see if I get faster response on the gauge. It seems fine, but maybe it would be faster than it is now.... Hard to tell... I have nothing to compare it to. Jay Powered by mwForum 2.10.2 © 1999-2007 Markus Wichitill |
